Like Tree5Likes
  • 1 Post By ms3blackmica
  • 4 Post By BigRedSpecial
 Old 07-28-2013, 03:34 AM   #1
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Default Possible cold start fix
In the past, I have tried lowering the commanded idle speed at low ECT's with zero luck as many of us have sure tried and put it off to lack of control.
I decided to make a more drastic change in the idle speed table by setting the entire ECT range to my desired operating temp idle speed. Why not?
No more 2000 RPM loud cold start ups! Instead I am seeing around ~1300-1400 (tach reads 100-200 rpm higher) on initial start and then coming right down to 800. I've tried this every morning for 3 days and so far it is working. It may take a little longer for the engine to warm up in colder temperatures but as of right now I am okay with the calm cold starts.
Can you guys try this out as well and report back?
Set Idle speed tables A & B the same and to your desired RPM.
Gen 1:
Gen 2:
Mfinlay04 likes this.
www.tunedbynishan.com
The Following 8 Users Say Thank You to ms3blackmica For This Useful Post:
802MS3 (07-29-2013), BigRedSpecial (07-28-2013), Easter Bunny (08-05-2013), Kdawg207 (07-31-2013), lobitoPU (07-28-2013), Mfinlay04 (05-27-2014), Micha (07-31-2013), rfinkle2 (07-29-2013)
 Old 07-28-2013, 03:36 AM   #2
Say Chi Sin Lo's Avatar
Posts: 872   (View Stats)
I too have wondered why the car "freaks out" when it has to wake up...
But then again, what's wrong with the factory setting? Aside from being loud as s*** and having a 2,000rpm idle, what's wrong with the factory setting?
Also, not sure if you guys know this, but my 04 NA Mazda 3 has a fairly calm cold-start routine. RPM jumps to ~1,500 and it calms down in a matter of ~10-15seconds. The MS3 takes ~40seconds to hover around 1,250rpm. (I timed it)
 Old 07-28-2013, 03:38 AM   #3
Nishan
Nothing is wrong with them. In fact, they are set up properly.
Many people just cannot deal with how loud their cars are specially if they live in an apartment complex and leave for work very early.
The Following 6 Users Say Thank You to ms3blackmica For This Useful Post:
802MS3 (07-29-2013), atvfreek (08-01-2013), Easter Bunny (08-05-2013), Micha (07-31-2013), rfinkle2 (07-29-2013), SLOWHATCH (07-28-2013)
 Old 07-28-2013, 08:58 AM   #4
Quigs's Avatar
Posts: 1,152   (View Stats)
I'll be giving this a try...mine doesn't hold at 2000 rpm for very long but it goes from like 1500 then bursts to 2000 then back down to 1250 and I'm sure my neighbors in the apartment complex don't like that sudden burst as I start the car for work at 6 AM haha.
2009 Mazdaspeed3
2000 Mazda Miata MX-5
NASA TTE build ongoing
 Old 07-28-2013, 09:54 AM   #5
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
Groans: 56
My neighbor has a shi'tzu that fucking barks relentlessly. His bedroom is directly adjacent my driveway. I love my 2000rpm cold starts.
Needed: Driver mod
The Following 10 Users Say Thank You to BigRedSpecial For This Useful Post:
atvfreek (08-01-2013), CosmicArkie (07-28-2013), Easter Bunny (08-05-2013), fivefingerdeathpunch (07-29-2013), killer-ms3 (07-29-2013), MarineMazda (07-28-2013), Micha (07-31-2013), Pointless (07-29-2013), Quigs (07-28-2013), Tomas (09-30-2016)
 Old 07-28-2013, 10:31 AM   #6
MZRSPEED's Avatar
Posts: 550   (View Stats)
MZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the worldMZRSPEED is the leader of the world
If you apply pressure to the pedal, then release as soon as it cranks your car will idle just like a hot start. I've been doing it for a while now, since I deleted my muffler/cat.
There is a thread about it somewhere, that's how I learned.
Sent from my iPhone using Tapatalk 2
2013 CWP - HPFP - 80d RMM - 3.5" INTAKE - CAT LESS EXTENDED DOWN PIPE - 3PORT - METH/WATER INJ D03
First 11 sec stock turbo MS3: 1.688, 7.676 @ 91.71 11.977 @ 113.85
MZRSPEED is offline   Reply With Quote
The Following 5 Users Say Thank You to MZRSPEED For This Useful Post:
daafisch (08-01-2013), ganque (07-29-2013), Micha (07-31-2013), mxlplx71 (07-28-2013), Tomas (09-30-2016)
 Old 07-28-2013, 10:33 AM   #7
Nishan
Yep I am aware of that trick.
I just want to know if this setting has the same effect on my car as it does on other models/years.
 Old 07-28-2013, 10:56 AM   #8
Volcom8190's Avatar
Posts: 448   (View Stats)
Volcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the worldVolcom8190 is the leader of the world
my car literally would not start with the ported manifold and the big turbo. although my idle is set to stock values.
2010 - BMW 335i M-Sport - Lemans Blue Metallic
2005 - Kawasaki ZX-6R 636 - Magma Red
Volcom8190 is offline   Reply With Quote
The Following User Says Thank You to Volcom8190 For This Useful Post:
Micha (07-31-2013)
 Old 07-28-2013, 11:53 AM   #9
Nishan
Did you scale the MAF for a larger intake?
Micha (07-31-2013)
 Old 07-28-2013, 12:19 PM   #10
Volcom8190's Avatar
only thing i changed was the idle table, tune is +3%/-1% on calibration across entire curve.
Micha (07-31-2013)
 Old 07-28-2013, 12:19 PM   #11
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Just gave this a try on my Gen2 and it seems to exhibit the same behavior as your car Nishan. RPM rises to 1500 then slowly falls.
 Old 07-28-2013, 12:36 PM   #12
Nishan
Well that's better than 2k lol
Thanks for trying that out Matt.
Agent_Orange (07-28-2013), Micha (07-31-2013)
 Old 07-28-2013, 12:42 PM   #13
Nishan
Oh so you set the idle tables the way that I posted in the OP and the car would not start?
Thanks for posting BTW. I know the table posted is not technically proper.
I am just testing.
Micha (07-31-2013)
 Old 07-29-2013, 01:41 AM   #14
fivefingerdeathpunch's Avatar
Posts: 437   (View Stats)
Cold Start - YouTube
volbeat ftw.
btw are your cars just that quiet or is 2k vs 1.5k really making that much of a difference? my car is much louder on cold start..
The Following User Says Thank You to fivefingerdeathpunch For This Useful Post:
Agent_Orange (07-29-2013)
 Old 07-29-2013, 02:46 AM   #15
Groans: 665
volbeat ftw.
Well I'm still stock exhaust, once my downpipe goes on I bet it will be a bit louder.
 Old 07-29-2013, 08:38 AM   #16
Nishan
The "Desired RPM" Monitor on my Dashhawk has always worked properly and this morning I referenced it to ECT while the car warmed up and there is some compensation being multiplied to my target RPM until a certain ECT is reached.
I was only able to start around 80*F but I wrote down the target RPM's at each ECT breakpoint to determine what the compensation is.
My next step is reduce my target RPM's by that compensation factor and see if that brings me directly to 800 RPM on a cold start.
The Following 4 Users Say Thank You to ms3blackmica For This Useful Post:
Agent_Orange (07-29-2013), BigRedSpecial (07-29-2013), Easter Bunny (08-05-2013), Micha (07-31-2013)
 Old 07-29-2013, 09:07 AM   #17
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
i always hold the pedal 1/4 way down and let off as soon as it fires, idels low no roaring to life
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following 2 Users Say Thank You to mxlplx71 For This Useful Post:
atvfreek (08-01-2013), Micha (07-31-2013)
 Old 07-29-2013, 09:09 PM   #18
Nishan
I have confirmed on my gen 1 that once the ECT has reached 106*F there are zero compensations applied to the RPM targets in the idle speed table.
Will have to wait until morning to test more on cold start compensations.
Last edited by ms3blackmica; 07-29-2013 at 09:09 PM. Reason: MSF Database - Automerged Doublepost
Agent_Orange (07-30-2013), Micha (07-31-2013)
 Old 07-29-2013, 09:45 PM   #19
blackms3_71's Avatar
Posts: 2,250   (View Stats)
I like the idea, you had said that there is nothing wrong with the stock values so when does mazda have it set to 2k? Vs say normal 800 on cold starts? Just to warm the motor a little quicker?
 Old 07-30-2013, 05:30 PM   #20
Hey i went ahead and did the same changes to my map. I have a 08 ms3. I changed tables A&B to 800 rpm across the whole table like you. Anddd it WORKED!! Car started up to about 1500 rpm and according to the ap the ect was 84 degrees. I made a video but i dont know how to upload it from my phone. Thanks bro it was so nice for the car to start up "normal" and not loud as hell.
ms3blackmica (07-30-2013)
 Old 07-30-2013, 05:51 PM   #21
I'd like to know too. Because I've always associated my cold starts with this:
The Following 4 Users Say Thank You to Say Chi Sin Lo For This Useful Post:
Agent_Orange (07-31-2013), ms3blackmica (07-30-2013), mxlplx71 (08-01-2013), snailD (07-30-2013)
 Old 07-30-2013, 08:58 PM   #22
Lol
 Old 07-31-2013, 04:53 AM   #23
Groans: 56
HA! Exactly what mine is like. Then 30 seconds later he settles down for a cup of tea.
Needed: Driver mod
The Following User Says Thank You to BigRedSpecial For This Useful Post:
Spectrix (07-15-2014)
 Old 07-31-2013, 05:04 AM   #24
It was nice to start the car this morning and it wasnt loud what a change that makes
 Old 07-31-2013, 11:59 AM   #25
Nishan
As previously mentioned, I discovered that there was an obvious compensation being applied to the target RPM's in the idle speed table up until ~104*F.
I could spend the next 2 weeks plotting graphs to figure out the compensation applied but IMO Cobb should release these controls to us. It appears to simply be an RPM compensation referenced by engine coolant temperature. I have seen such compensation tables before in other PCM's and standalones.
I decided to make a much more drastic change to the idle speed targets near my cold start temperatures to counteract the compensation and sure enough I am now getting a desired idle speed of about ~1300 RPM on cold start.
 Old 07-31-2013, 03:06 PM   #26
Cold Start Test 3 - YouTube
I can try that too if you like to have a 2nd reference, at 800 rpm set in the a&b table my cold starts is about 1500 rpms so now that you changed it to 350 rpms(lol) you are seeinf only a 200 rpm decrease? cobb should give us those tables.
oh and I had a question for you. my tables shows temps in Celsius not in Fahrenheit how do I change that I didn't see a option in any menu
Last edited by blackms3_71; 07-31-2013 at 03:06 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-31-2013, 03:13 PM   #27
Nishan
Edit -> Configure Options -> Display -> Show Standard Units
blackms3_71 (07-31-2013)
 Old 08-01-2013, 07:01 AM   #28
Jkspeed's Avatar
Posts: 293   (View Stats)
Jkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond repute
Groaned at 6 Times in 4 Posts
That part throttle trick is pretty neat for when I'd rather not get yelled at by my friends neighbors.
Jkspeed is offline   Reply With Quote
 Old 08-05-2013, 02:28 PM   #29
rob ms6gt's Avatar
Posts: 416   (View Stats)
I think the reason for the 2000 rpm start is to get the cats heated up quicker.
ROB MS6GT
 Old 08-05-2013, 02:56 PM   #30
mxlplx71's Avatar
Groans: 128
that makes sense, but I haz no cats
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
Agent_Orange (08-05-2013)
 Old 08-05-2013, 06:55 PM   #31
rob ms6gt's Avatar
Me neether.
ROB MS6GT
 Old 05-11-2019, 06:53 AM   #32
ysaliens's Avatar
Posts: 22   (View Stats)
ysaliens can only hope to improve
Any problems with the ECU map change compensation?
ysaliens is offline   Reply With Quote
The Following User Says NO Thank You to ysaliens For This Un-useful Post:
Vansquish (05-11-2019)
 Old 05-11-2019, 07:29 AM   #33
Police - Grammarhead
Vansquish's Avatar
Six year thread necro. Nice. Not even sure what you're trying to ask.
 Old 05-12-2019, 10:42 AM   #34
ysaliens's Avatar
I was wondering if those running the compensanted maps have had odd side-effects. 6 years is a long time but any issues would also come up by now.
The table still applies as far as I can tell.
Ms3 cold start noise not vvt 2.0t03speed MazdaSpeed 3 - Engine, Transmission & Driveline 10 03-15-2013 09:38 AM
Struggle to start with E on cold start specvspeedfreak MazdaSpeed 3/6 - E85 Fueling 3 03-10-2013 04:51 PM
what's your idle on cold start? drag0nfire Mazdaspeed3/6 General Discussion 15 04-15-2012 02:41 PM
Cold Start up PapaSmurf Gen2 MS3 General Discussion 16 03-29-2011 04:30 PM
Page generated in 0.53344 seconds with 33 queries
