 Old 10-05-2015, 10:42 AM   #1
Kris Yavorsky's Avatar
Posts: 7   (View Stats)
Kris Yavorsky is an unknown quantity at this point
Default Question About My AP Tune
I recently bought an accessport to monitor my car after having some fuel cut out issues caused by my catless downpipe. Didn't know that I needed upgraded fuel pump internals at the time, the car ran fine for 3 months or so and then it started losing fuel pressure. So I now have autotech internals installed.. I'm running the Stage 1 + DP map.. Stock airbox, hpfp internals, catless downpipe. I know that Cobb suggests their own product in the maps list description (cobb downpipe with 1 cat).. Will I run into any issues running this tune with my catless downpipe? My car is hardly modified. I just ordered some denso itv22 plugs as well since it looks like that's a requirement with the AP... Any info? I'm not all too knowledgeable with all of this.
Kris Yavorsky is offline   Reply With Quote
 Old 10-05-2015, 08:02 PM   #2
sheston's Avatar
Posts: 1,847   (View Stats)
Do some WOT logs and look at the results. Lots of info on here to learn how to read them
 Old 10-05-2015, 10:57 PM   #3
08mzr's Avatar
Posts: 641   (View Stats)
08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world
It'll be best to find a tuner you like and get a tune from them. Even if it's just an OTS tune. I just got a Freektune OTS+ and it made a HUGE difference in how the car acts vs the Cobb OTS. It's only $75 which is a lot cheaper than an engine if ething goes wrong.
2008 Metro Gray Mica Speed 3-SOLD
Corksport SRI
Corksport TIP
JBR 80 duro RMM
Cobb AP v3
Autotech internals
CX Racing FMIC
SPC rear camber arms
Hawk HPS pads front and rear
FREEKTUNE OTS+
1998 Civic - SOLD
2011 Speed3 200k+ miles Stock -Daily
08mzr is offline   Reply With Quote
 Old 10-06-2015, 01:30 AM   #4
btstarcher's Avatar
Posts: 4,852   (View Stats)
You need to use the correct map for your mods. When does Cobb suggest using a Stage 1 map? I thought those were for people with no HPFP upgrade?
SnailTune in progress
 Old 10-06-2015, 06:23 AM   #5
This is the probably the map he's running COBB STAGE 1 + DP MAP
btstarcher (10-06-2015)
 Old 10-06-2015, 10:46 AM   #6
btstarcher's Avatar
Yeah, that's the wrong map. OP you need to run the stage 2 map since you have upgraded HPFP internals and downpipe.
 Old 10-12-2015, 01:29 PM   #7
It's running a stage 1 + dp map.. It requires hpfp internals, which I have. As well as the stock intake. The only thing I was curious about was the dp, cause mines a catless one. It seems like the Cobb ones are catted. I wanted to know if that would be an issue with the tune I'm running.
I've had a couple people suggest that. I'm waiting on my denso plugs to show up in the mail. I guess I'll put those in before I do any other tuning.
Last edited by Kris Yavorsky; 10-12-2015 at 01:29 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-12-2015, 05:10 PM   #8
btstarcher's Avatar
Wrong. You need the stage 2 map. Did you even read the notes? I double checked, and yep.
Sent from my XT875 using Tapatalk
 Old 10-12-2015, 05:18 PM   #9
Stage1+DP 91 OCT or 95 RON
Intake Requirements: Stock
Intercooler Requirements: Stock
Fuel Requirements: 91/92 OCT or 95 RON fuel Cam Driven Fuel Pump: Autotech High Volume Fuel Pump (CDFP) required
Exhaust Requirements: Stock or upgraded cat-back exhaust, COBB High Flow Downpipe required
Boost Targets: 17psi peak tapering down to 16psi by redline +/- 1.5psi
 Old 10-12-2015, 05:29 PM   #10
btstarcher's Avatar
No. Read the stage 2 notes.
 Old 10-12-2015, 05:33 PM   #11
I have read the notes for stage 2 maps.. I don't have the supporting mods for those. I have the supporting mods only for the map that I displayed above. I don't have an upgraded intake or turbo inlet hose that all of the stage 2 maps call for..
 Old 10-12-2015, 05:41 PM   #12
btstarcher's Avatar
I guess Cobb does their maps differently then. Stage 2 used to mean exhaust and HPFP, regardless of intake.
 Old 10-12-2015, 08:02 PM   #13
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
I think that map will probably be suitable. Probably not going to make much of a difference either way. Are you at all interested in learning to use Accesstuner Race and adjust the wastegate settings yourself? It's not terribly difficult and it'll guarantee that you don't hit any fuel cut or anything (plus you can smooth things out and get a nice consistent boost response across the board). I can link you to some threads that will help teach you how to do this. Really all you need is a laptop and a USB cable and you can start tuning right away. ATR is free...included with your AP.
Side note: I would recommend an intake as your next upgrade.
2007 Mazdaspeed3 GT
Boost_creep (10-13-2015), MS3Shadow (10-13-2015)
Question on e85 tune joewarner Stratified Automotive Controls 6 09-06-2013 01:50 PM
Cobb tune question btstarcher MazdaSpeed 3/6 - ECU Computer Tuning 14 02-11-2013 06:02 AM
question on exhaust with a tune rgvms6 MazdaSpeed 6 - Engine, Transmission & Driveline 13 05-07-2012 09:11 PM
Stage 1 OTS tune help/question captain slow MazdaSpeed 3/6 - ECU Computer Tuning 3 03-06-2012 07:39 PM
General Tune Question Onelovesoccer 2010 MS3 - ECU Computer Tuning 1 01-04-2012 08:27 AM
Page generated in 0.33015 seconds with 25 queries
