| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() | | #41 | ![]() |
![]() Join Date: Sep 2008 Location: Phoenix, AZ
Rep Power: 1352 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 813
| Not Ranked : 0 score
__________________ Some things. |
![]() | | #42 | ![]() |
| Lurkers
Posts: n/a
| whats BT besides for my initials?? edit, is that BIG TURBO???? |
![]() | | #43 | ![]() |
| Not Ranked : 0 score Yea, Bigass Turbo
![]() | | #44 | ![]() |
| Lurkers
Posts: n/a
| i hurd BigASS turbos can suck little children in them and because i live near a school i wont get one. speed is not worth murder |
![]() | | #45 | ![]() |
![]() Join Date: Feb 2009
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score What is the torque specs for the spark plugs? I will be getting densos soon. |
![]() | | #46 | ![]() |
| Lurkers
Posts: n/a
| 8-10 ft lbs |
![]() | | #47 | ![]() |
| Not Ranked : 0 score That seems very low for a boosted car |
![]() | | #48 | ![]() |
![]() Join Date: Nov 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score subbing... interesting topic
__________________ |
| The Following User Says NO Thank You to SonnyBonahoe For This Un-useful Post: |
![]() | | #49 | ![]() |
![]() Join Date: Jun 2008
| Not Ranked : 0 score what gap? i had missfire toady nothing big I will strech spring in my coild and look at plugs...what gap for fully bolted car making around 280whp?? I have denso step colder plugs |
![]() | | #50 | ![]() |
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score scroll to the top of the page and click on thread tools > subscribe to thread. don't post "subbing" please .030 eh |
![]() | | #51 | ![]() |
![]() | | #52 | ![]() |
![]() ![]() Join Date: Jun 2009 Location: PDX
Rep Power: 5715 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,677
Groans: 90
| Not Ranked : 0 score what type of plug gapping tools are you guys using? |
![]() | | #53 | ![]() |
| Not Ranked : 0 score The cheap 99c coin from autozone works fine for me, doesn't have to be dead on.
![]() | | #54 | ![]() |
![]() | | #55 | ![]() |
Groans: 90
I compared the feeler gauge 0.028 against the $0.99 gapper, and the cheap gap tool is so far off it's not even funny...
__________________ ![]() [SIGPIC][/SIGPIC] | |
| The Following User Says Thank You to hnda etr For This Useful Post: | flappypaddles (11-30-2013) |
![]() | | #56 | ![]() |
![]() Join Date: Jan 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 952
Groans: 70
| Not Ranked : 0 score ^^^ feeler gauge is the way to guy, way more exact. back to plugs tho, i have been using the itv-24 2 step colder for awhile now no issed i switched from the 1 step. noticed big decreace in knock from 1 step to 2 step. |
![]() | | #57 | ![]() |
Groans: 90
| Not Ranked : 0 score how are you noticing the knock? datalog with AP or DH? My AP datalogs show hardly any KR w/ITV-22's.... But then again, I didn't have a lot of KR with the OEM plugs either...
![]() | | #58 | ![]() |
Groans: 70
| Not Ranked : 0 score AP. i did not have ap with stock plugs so i could not comment. but just simple switch from step 1 to 2 made a reduction in knock. i just recently applied the ol cl fix to my stage 2 setup and wow knock is almost 96% better/gone |
![]() | | #59 | ![]() |
Groans: 90
| Not Ranked : 0 score Huh?
![]() | | #60 | ![]() |
Groans: 70
| Not Ranked : 0 score open loop/ closed loop makes it go open loop faster. http://www.mazdaspeedforum.org/forum/foru...op-tables.html |
![]() | | #61 | ![]() |
Groans: 90
![]() | | #62 | ![]() |
| The Kamikaze King! ![]() Join Date: Jun 2008
Rep Power: 1829 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,794
Groans: 754
| Not Ranked : 0 score I just got my Denso ITV 22 plugs, they appear to be gapped to 0.028 with one at 0.030 so I tightened that one up to 0.028 also. I will be running an ATR modified Stage 1+ map. Cobb says: "Our data has shown that the factory spark plug temperature range (6) and gap (~.034”) are sufficient for stock boost levels and normal driving conditions. Although, operating the car with higher than stock boost levels or with the calibrations that are on the AccessPORT, require that a spark plug gap of .026” - .028” (6.6 – 7.1mm) be used on a 1-step colder temperature plug. Denso currently offers this spark plug as part # ITV22 (please be sure to verify each plug is properly gapped before installing them). Our experience has shown that operating your turbo-charged engine at higher than stock boost levels requires that your spark plugs be replaced at around 15,000 mile intervals." So what gap are you guys running the Denso ITV22 at?? Give answer as gap, and map you run.
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. |
![]() | | #63 | ![]() |
Groans: 90
Optionsauto.com <-- got mine here
__________________ ![]() [SIGPIC][/SIGPIC] Last edited by hnda etr; 08-24-2009 at 08:53 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #64 | ![]() |
![]() Join Date: May 2008
Rep Power: 414 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 105
| Not Ranked : 0 score .026/18 psi ATR map - I just tapped them a little to see if I could get them down to .026 and basically did. Gapping these things is not fun and I'm not confident in the accuracy of doing it by hand. To someone above - jets have 3 altimeters so they have a tie breaker, i.e. how do you know which was off if you only compared two?
__________________ ![]() |
![]() | | #65 | ![]() |
![]() Join Date: Jan 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 8
| Not Ranked : 0 score Has anyone ran the copper plugs listed in the op? Been looking for a 1 step colder copper plug, but did not think they existed for the mazdaspeeds until I saw the ngks in the op but no comments on temp rating on them. |
![]() | | #66 | ![]() |
![]() Join Date: Apr 2009 Location: BPT Connecticut
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 72
| Not Ranked : 0 score Breathing some fresh life into this thread. How did everyone's results turn out? I've heard a few horror stories about going one step colder on plugs? Now that its time for me to swap mine out i'm wondering how the Denzo's VS the NGK's worked out?
![]() | | #67 | ![]() |
![]() Join Date: Nov 2010 Location: Reading, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,158
Groans: 731
| Not Ranked : 0 score wow
__________________ Mods: stock Eventually I'll pay for how I am....but it won't be by the hand of any of you faggot fucks here. |
![]() | | #68 | ![]() |
![]() Join Date: Jan 2014
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
| Not Ranked : 0 score Been a step colder in ngk from 30k to 115k no problems
__________________ building motor, 3071gtx,cp-3 tbe,cpe 3.5 full intake , 3bar map , cp-e front mount, cp-3 hpfp Pnp im, Tial 38mmewg, JBR rear sway bar, BC Racing extreme drop coils, Spc camber arms, Ugly garage door lip for now lol, xxr 527s,FreekTune! |
![]() | | #69 | ![]() |
![]() Join Date: Apr 2014 Location: The Netherlands
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 512
| Not Ranked : 0 score For the metric people out there, how should I use the 0,26 -0,28 value? I believe you mean 0,26-0,28 thou? that will be 0,026-0,028 inch, and that will be 0,66-0,71mm? Do I stand correct in this? @Haltech; And I believe NGK is pre gapped at 0,044 inch / 1.1mm. In post # 22 NGK says the following: While this plug is dimensionally correct I would not suggest using the LTR7IX-11 for this application as the gap setting is too large (factory set to .044"). You do not want to gap any plug more than .008" from where it is factory set, as more than this and the inner surfaces between the electrodes will not be parallel and can cause the plug to misfire and wear out very quickly (iridium plugs seem to be very sensitive to this gap adjustment range especially under boost). Anybody have some experience with this? Because if you want to gap these to 0,26-0,28 you will have to close the gap by 0,16, which they don't recommend, but how is this working out in real life for everyone?
__________________ MazdaSpeed3 GT '07 CP-e Xcel Nano 3" Air Intake - CP-e Nviscid 3" TIP - CP-e HPFP - CP-e DeltaCore FMIC - CP-e Stage 1 RMM - ACT clutch kit - ATP Race Pipe - SU DualPort Turbosmart BPV - COBB anti swaybars - COBB Sport Springs - Goodridge Brakelines - Whiteline Swaybar endlinks - JBR SSP - Damond Motorsport OCC AccessPort V2 Self tuned Last edited by Snip; 07-24-2014 at 12:27 AM. |
![]() | | #70 | ![]() |
![]() Join Date: Nov 2013 Location: Jackson, TN.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23
| Not Ranked : 0 score Stock plugs changed at 6,000 (first oil change) 2nd set NGK 3787 Iridium (would cut out at higher rpms after modding the vehicle) (stock gap .044) 3rd set NGK 6510 1 step colder (gapped to .028) runs great but still cuts out above 5,000 rpms. Gas mileage however has consistently dropped by 3- 5 mpg. I plan on buying the Denso 2 step, i will gap to .028 with feeler gauge and then report back. My current mileage is about 79k.
__________________ 09 MS3 GT (japan build): CPE Stage 1 Block, Custom ported & polished IM, AutoTech internals, CPE CAI, Cobb short shifter, Cobb downpipe, OBX 3" full exhaust cat delete, COBB Turbo Inlet, Streetsmart bypass valve. Raceland Coilovers, Moog Upper Strut Mounts (front) Shock Mount (rear) Denso IVT24 2 step plugs, HID, Corksport LED interior lighting, Stop Tech drilled & slotted rotors front and rear, Wearever Platinum pads, VSR 18" Staggered Wheels 18 x 8, 18 x 9.5, Cobb AP V3, Vent Pod Guage, Eonon GM5151U |
| The Following User Says Thank You to GOAT For This Useful Post: | HighSun_Murder (07-28-2014) |
![]() | | #71 | ![]() |
Plugs came in yesterday. Straight out the box the gap was .032 instead of the labelled .044. All four were the same. So if anyone is worried about reducing the gap to work for our vehicle more than likely you will be o.k. Also i used a digital and manual feeler gauge so the reading were within a thousandth. In the vehicle the idle was just a tap lower. Which i liked. Can't elaborate on cut out or performance yet, need to re-tune due to other issue but will keep you posted. So far my vote is to skip the step 1. P.S. also on a side note Step 1 NGK plugs were $9.07. The Step 2 Denso plugs were $6.99!!!!!
__________________ 09 MS3 GT (japan build): CPE Stage 1 Block, Custom ported & polished IM, AutoTech internals, CPE CAI, Cobb short shifter, Cobb downpipe, OBX 3" full exhaust cat delete, COBB Turbo Inlet, Streetsmart bypass valve. Raceland Coilovers, Moog Upper Strut Mounts (front) Shock Mount (rear) Denso IVT24 2 step plugs, HID, Corksport LED interior lighting, Stop Tech drilled & slotted rotors front and rear, Wearever Platinum pads, VSR 18" Staggered Wheels 18 x 8, 18 x 9.5, Cobb AP V3, Vent Pod Guage, Eonon GM5151U | |
| The Following User Says Thank You to GOAT For This Useful Post: | HighSun_Murder (07-30-2014) |
![]() | | #72 | ![]() |
| Not Ranked : 0 score You got a link for the plugs? I read earlier in this thread the the Denso's were garbage?
![]() | | #73 | ![]() |
However I buy most of my over the counter stuff from a local Advance Auto parts store, so i just gave them the four digit part or stocking number (5341) mentioned in my post above and they ordered it straight from Denso. It was cheaper than most prices i saw online and they didn't tack on any shipping.
__________________ 09 MS3 GT (japan build): CPE Stage 1 Block, Custom ported & polished IM, AutoTech internals, CPE CAI, Cobb short shifter, Cobb downpipe, OBX 3" full exhaust cat delete, COBB Turbo Inlet, Streetsmart bypass valve. Raceland Coilovers, Moog Upper Strut Mounts (front) Shock Mount (rear) Denso IVT24 2 step plugs, HID, Corksport LED interior lighting, Stop Tech drilled & slotted rotors front and rear, Wearever Platinum pads, VSR 18" Staggered Wheels 18 x 8, 18 x 9.5, Cobb AP V3, Vent Pod Guage, Eonon GM5151U Last edited by GOAT; 10-17-2014 at 09:42 AM. Reason: Adding the stocking number for spar plugs | |
![]() | | #74 | ![]() |
![]() | | #75 | ![]() |
| Not Ranked : 0 score humm....
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/spark-plug-database-colder-than-stock-stage-5691/ | ||||
| Loss of power on any MAP - Page 6 - COBB Forums | This thread | Refback | 05-22-2008 01:14 PM | |
| Loss of power on any MAP - Page 6 - COBB Forums | This thread | Refback | 05-22-2008 06:57 AM | |
| Loss of power on any MAP - Page 6 - COBB Forums | This thread | Refback | 05-22-2008 03:39 AM | |
| Spark Plug Database - Colder Than Stock ( Stage 1&2 ) | Haltech | MazdaSpeed 6 - Engine, Transmission & Driveline | 41 | 05-05-2016 08:49 AM |
| Spark Plug Database - Colder Than Stock ( Stage 1&2 ) | Haltech | MazdaSpeed 3 - Engine, Transmission & Driveline | 205 | 09-22-2015 06:52 PM |
| Spark Plug Gap | khaydin | Cobb Access Port/Maps | 5 | 12-01-2008 10:17 PM |
| HKS spark plugs installed *2 steps colder than stock | whoosh@Realtune | MazdaSpeed 3 - Engine, Transmission & Driveline | 17 | 10-02-2008 02:15 PM |
| Spark plug gap | Jesse MS3GT | MazdaSpeed 3 - Engine, Transmission & Driveline | 6 | 03-16-2008 04:53 PM |
