 Old 01-28-2019, 07:44 AM   #1
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
Default VersaTuner Feature Update
For those who have not checked out VersaTuner lately, here are some links to the features and list of included tunes. We are actively developing VersaTuner for Mazdaspeed 3/6, and with our new in-house dyno, we are adding new tunes to the included off-the-shelf tunes list.
VersaTuner features and included off-the-shelf tune list
VersaTuner for Mazdaspeed6 https://www.versatuner.com/features/...zda-6-mps-gen1
VersaTuner for Gen1 Mazdaspeed3 https://www.versatuner.com/features/...zda-3-mps-gen1
VersaTuner FAQ https://www.versatuner.com/faq
VersaTuner User Forum VersaTune User Forum
Steve
Lead Tuner
The Following User Says Thank You to Steve@VersaTune For This Useful Post:
Code Monkey (01-28-2019)
 Old 01-28-2019, 08:27 AM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Ok. The only "feature update" is more OTS tunes?
I don't speak for everyone, but I feel confident in saying that most people don't use OTS tunes. Most likely because of the stigma around COBB OTS tunes being "complete garbage".
There is enough information readily available on MSF to get ANY Speed running with Versa or AP. And actually, I find it very necessary for users to do the research and figure this stuff out. You learn a lot about tuning along the way. There are How-To's on setting up a base tune. There are MAFCALs ready to go with a simple copy/paste that really only need a touch-up for the specific vehicle.
I'm not a "pro-tuner", but I've tuned my car with Versatuner since the beginning. Maybe that's why I feel the way I do.
I like Versatuner and I push others to join the Versatuner team, but I think developing OTS tunes is the wrong place to spend resources.
Do you have radiator fan control worked out?
I've heard others have a similar issue as me where cold starts need either a quick tap of the gas pedal or constant pressure on the gas pedal to maintain idle. I'm used to it now. Been dealing with it since I installed VT 2 something years ago.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 01-28-2019, 08:42 AM   #3
Our OTS tunes are developed and tested on real cars.
All new OTS tunes include real dyno charts created on our new in-house dyno.
Our OTS tunes are fairly conservative. We don't push timing to the bleeding edge.
For instance, the Gen2 OTS tune we just released has been on my daily driver for 3 years without issue.
The fans are not directly controlled by the ECU. There is a fan controller. That has made it difficult to figure out how to control fans.
Is the cold idle specific to MS6? I have seen issues on my MS6, but I attributed it to the blow-through MAF.
My gen2 idles fine at startup in sub-zero F weather.
There are cranking and after-start enrichment tables exposed. Have you tried adjusting that?
Steve
Lead Tuner
 Old 01-28-2019, 09:46 AM   #4
Fstrnyou's Avatar
I have not adjusted cold start or afterstart enrichment tables but I am trying to get a local to share his with me to see if there are any differences. It's been an issue since I first flashed VT when I was stock.
Other rides:
History:
Official VersaTuner Feature Request Thread Steve@VersaTune VersaTune 289 01-02-2019 04:56 AM
AP vs Versatuner smileyIV MazdaSpeed 3/6 - ECU Computer Tuning 17 06-07-2018 07:36 PM
Versatuner GB aviator79 CX-7 > General Lounge + New Member Welcome 5 03-12-2013 01:10 PM
VersaTuner for CX-7 steve12345 CX-7 > Turbo Induction & ECU Tuning 50 07-07-2012 08:42 AM
Update on datalogging feature? steven88
Cobb Access Port/Maps
3 12-03-2008 10:51 PM
Page generated in 0.32412 seconds with 21 queries
